Content on Master Page doesn't show up in the space provided
rstetson
Post by rstetson » Mon May 16, 2016 5:22 pm
I'm trying to build a new website with a Master Page layout for all the pages.
I've constructed the master and it looks fine, but when I try to insert content into a page, the content appears at the bottom of the master page, not where the place holder is.
I am set up exactly the way the help files say to be set up for master pages. HELP!
do I have to designate headers and footers as well? Doc doesn't say anything about that.
rsl
Re: Content on Master Page doesn't show up in the space prov
Post by Pablo » Mon May 16, 2016 6:19 pm
Are you referring to master pages or master frames?
Maybe you have mixed up the two concepts?
viewtopic.php?f=10&t=41184
To be able to help you I need to see your project so I can see what you have done.
rstetson
Post by rstetson » Sun Jan 15, 2017 5:05 pm
OK, sorry for the delay in responding....
I am not sure whether I'm using Master Frames or Master Pages.....
I created a page I called "Master" with a content place holder.
I do have some left side fixed content in the Master along with fixed content on the top and bottom.
When I set up the page with the master frame, the content doesn't show up in the space provided, but appears down at the bottom of the page.
so: 1. can the Content Place Holder only occupy the entire master space horizontally?
the active site is at http://depost6.delegion.org
thanks
rstetson
Post by rstetson » Sun Jan 15, 2017 5:06 pm
Ooops. The only link on the page that uses this right now is the "Links" off the yellow menu.
thank you
rsl
Post by Pablo » Sun Jan 15, 2017 5:25 pm
Please remove all code you have manually added, so we can be sure this is not an issue of invalid/external code.
