How to Animate the text by scrolling?
ordanax
Post by ordanax » Fri Apr 28, 2017 12:00 pm
Hi, I try animate text (not object or image) by scrolling. I need get animation then text will appear on monitor, but it started immediately!
Trigger hover & focus have not change.
How I can do animate by scrolling?
Re: How to Animate the text by scrolling?
Post by Pablo » Fri Apr 28, 2017 1:49 pm
You can use bookmark events to trigger animations based on the current scrollbar position:
http://quickandeasywebbuilder.com/bookmark_events.html
ordanax
Post by ordanax » Fri Apr 28, 2017 3:31 pm
Thank you very much!
Now works when I scrolling, but I do not see transform-bounse-in effect in events (as in the photo http://joxi.ru/a2X3ZXGT1VMLVm )
Post by Pablo » Fri Apr 28, 2017 5:32 pm
You cannot directly use CSS3 animations in events, only JavaSctipt animations.
You will need to use Styles (classes) to trigger CSS3 animations.
Related tutorial:
http://quickandeasywebbuilder.com/animation_events.html
ordanax
Post by ordanax » Sun Apr 30, 2017 7:07 am
Ok, thanks.
