Lost publish profiles with Version 5
hrk
Post by hrk » Thu Jul 13, 2017 3:19 pm
Hello.
I just upgraded to V 5.0.3, and already have a problem: the publish profiles I used with version 3 do not show in the version 5 Publish Menu.
How can I get V5 to retrieve these profiles?
Sorry if this has been asked and answered before, but I couldn't find it in the forum.
Thanks in advance.
Heinz
Re: Lost publish profiles with Version 5
Post by Pablo » Thu Jul 13, 2017 4:34 pm
Maybe this will be helpful?
viewtopic.php?f=10&t=43939
hrk
Post by hrk » Thu Jul 13, 2017 5:32 pm
Hi.
Thank you for the pointer, it solves my problem of retrieving the information I need to reestablish the publish locations: I decided not to try copying registry data from one entry to the other.
However, I would like to suggest that you do something to provide a more straightforward way of moving values from existing Q&Easy configurations to a new version: playing with Registry entries is not something any user wants to or should be doing.
Cheers.
Heinz
Post by Pablo » Thu Jul 13, 2017 6:04 pm
The problem is that QWB is a multi platform application.
Not all platforms support the same features. For example, on a Mac you cannot access the configuration of another app/version for security reasons.
The same may be true for Linux.
hrk
Post by hrk » Sun Jul 16, 2017 8:18 pm
I work with softwares that have the same problem: they kept the config data in .ini files in Unix/Linux and for the sake of Windows compliance stored the same data in the registry.
Lately they threw compliance to **** and now keep everything in .ini files on all platforms. May be an idea to follow...
Cheers.
