won't publish files
johnrvd
won't publish files
Post by johnrvd » Wed Jul 19, 2017 6:51 am
I connect with my htp server okay.
When I "publish" I get this:
*** START OF PUBLISH ***
Scanning publish folder...
Found 12 file(s).
Initializing FTP connection...
Connecting to ftp.johnpaolucci.com...
Using PORT mode.
Succesfully connected.
Current directory is '/'
Setting remote folder to public_html...
Response from server: 550 Can't create directory: File exists
Uploading '1700-128-darktile.jpg'...
Unable to upload file: 425 Could not open data connection to port 10680: No route to host
Removing temporary files...
Publish failed!
*** END OF PUBLISH ***
I called my server and they advised that I ask quickandeasywebbuilder
The odd thing is, "Can't create directory: File exists" So is this software trying to create a folder on my FTP? In "remote folder" I typed "public_html". That's what my server said was the folder I should publish to.
Re: won't publish files
Post by Pablo » Wed Jul 19, 2017 2:04 pm
You are using PORT mode.
Please enable passive mode (the default)
