Ive had no way of using QuickNEasy Web Builder v 7 for some months now;
The software starts uploading pages (which previously went to the hoster fine and appeared OK,
But now the upload stops while uploading some odd item called "SearchIndex.js.
I dont know what JS fiiles are, I was sure I never added any, and cant find any in my pages.
Has anyone any clue what these JS items are, and is there a way i can tear them out of my pages and stop it using them?
Many Thanks
Searcheindex.js
Re: Searcheindex.js
searchindex.js is a file used by the built-in site search.
If you have a large website then it may take a long time to generate the file because it needs to parse all pages and create the index file.
You can disable this feature in Tools -> Site Search Settings
Re: Searcheindex.js
Pablo, You are my hero.
It worked perfectly. Immediately too.
A thousand thanks
Paul
A thousand thanks
Paul
