Up until today (3/4/21), I had no trouble publishing my website, Today, I added a carousel with 3 images. Each image has a link to a new page.
When I tried to publish, it goes along for awhile then it stops and I get the msg 'FTP server doesn't support passive mode'. I then tried to publish just my master page - same thing, failure. I then removed all of the images on the Master page - that worked. So then, I went to the 3 new pages I had created. Two published OK, the third didn't. The only difference among the pages is that each has a different poster. I then go to the index page and try to publish it. It goes for awhile, then gets hung up while uploading one of the images in the carousel.
Sometimes the publishing stops with the error message, sometimes it just hangs and I have to kill Quick n EZ
I am using QnEZ 2.3.5 on a Mac.
images causing site to not publish
Re: images causing site to not publish
First note that version 2.3.5 is no longer supported.
I do not think this has anything to do with the images
Maybe your webhost has changed something?
Based on the error message it looks like you are using standard FTP.
Maybe your host has switched to Secure FTP?
