Adding existing file to site map
reinecath
Post by reinecath »
I've read your note about the project files not reflecting the directory files, but can't figure out how to add an existing html file to the project when it doesn't appear in the site map. I've got a directory that has a qwb file (project.qwb) and a folder (project). The html file I want to publish is in the project folder, but does not appear in the site map or asset folder for project.qwb even after publishing the entire web, How can I include a file that exists in the project folder but not in the project.qwb site map?
reinecath
Re: Adding existing file to site map
Post by reinecath »
OK, figured it out. I used "import html from computer" under the Page menu. That added the page to my site map.
Correct!
