Preferences/Publish
michling
Preferences/Publish
Post by michling »
When setting preferences in the Publish tab, are they only for the site you have open, if you have one, or if no site is open, they are for all websites created after?
Re: Preferences/Publish
You can create a publish profile for each website. Just make sure you give each profile a different name.
See also the 'important' note in this tutorial:
https://www.quickandeasywebbuilder.com/publish.html
michling
Post by michling »
Maybe I did not make myself clear. I am talking about the Publish tab in Preferences.
When you add more file types and name a folder for those file type.
Specifically the Target Folder for File Types...
These settings are stored in the project file, so each project can have different settings. They are also used for new projects.
michling
Post by michling »
So, if no project is open then updating these preferences will affect all projects afterwards and if a project is open, then these preferences only affect that project.
Very interesting.
Thanks Pablo.
If no project is open then the settings will be the default for new projects. It will not affect existing projects.
