is Possible the implementation of Layer object?
vic53
Post by vic53 » Tue May 15, 2018 8:11 am
In the Layer object
[before tag][inside tag][after tag][custom style]
I wish to have another option where I can insert the value html inside it for example another tag <div>value...or an ...include statement</div>
or
How I can resolve if I want insert a include statement in it for a my external block?
thanks
best regards
Vincenzo M.
vic53
Re: is Possible the implementation of Layer object?
Post by vic53 » Tue May 15, 2018 8:31 am
I now tryed to make this and it seems works
I insert in the inside tag the string as down..
><div>value of the div</div
and in the output code it returns
<div id="Layer1" style="position:absolute;text-align:left;width:100%;height:85%;" ><div>value of the div</div>
</div>
that is what I want...
but this is a no good solution... I prefer a new option to make this...
thanks
Post by Pablo » Tue May 15, 2018 12:35 pm
Why not add an HTML object to the layer?
vic53
Post by vic53 » Wed May 16, 2018 1:23 pm
I want insert a new <div> .. </div> inside...
where is the object html?
Post by Pablo » Wed May 16, 2018 5:56 pm
You can find the 'HTML' object it the Toolbox or 'Insert' menu.
vic53
Post by vic53 » Fri May 18, 2018 6:07 pm
ok, I am studying the program editor...
I have write some code to make call to my server in mysql for a login routine with ADO...
This is the code I have used and it functions well...
[code for connection to MySQL 5.3 with parameters renamed...]
$cn = new COM("ADODB.Connection") or die("CANNOT START ADO");
$cnstr = "DRIVER={MySQL ODBC 5.3 Unicode Driver}; Port=3306;DATABASE=DBTEST;UID=username;PWD=password;";
$rs = new COM("ADODB.Recordset");
$rs1 = new COM("ADODB.Recordset");
[/code]
<?php
// Chiudo la connessione al DATABASE
// $cn->Release();
 $cn->Close();
 $cn = null;
 if (isset($_SESSION["DBSTATUS"])){
    $_SESSION["DBSTATUS"]="DB CLOSED OK..";
the function from the page to make the call
[function]
function Seleziona(pagina) {
document.<?php echo $FormName?>.action = pagina;
document.<?php echo $FormName?>.submit();
return true;
function AccessoAlSistema(U,P) {
var datiform="?username="+U;
datiform = datiform + "&password="+P;
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
var risposta=this.responseText;
var lista = risposta.split(";");
if (lista[0]=="0")
Seleziona(lista[2]);
else
document.getElementById("msg").value = lista[1];
xhttp.open("GET", "logon.php"+datiform, true);
xhttp.send();
[/code functions]
and the code php on the server
<?php
$Table="user";
// CONNESSIONE AL DATABASE
include('Connessione.php');
session_start();
//$userid="vic53";
//$password="merlino";
$username=$_GET["username"];
$password=$_GET["password"];
$SQL="select * from users where username='".$username."'";
$rs1->Open($SQL,$cn);
if ($rs1->eof == false)
 $pw=$rs1->Fields["password"]->value;
 if ($pw==$password) {
   echo "0;Login eseguito [".$username."]...;Homepage.php;";
   $_SESSION['username']=$username;
 else
   echo "1;password errata in accesso al sistema...".$userid.";Index.php;";
else
 echo "2;dati errati in accesso al sistema... ;Index.php;";
$rs1->Close();
include("Disconnessione.php");
Now i am writing the first page for my site...
thanks fro the answer
ciao from Italy
Vincenzo
vic53
Post by vic53 » Fri May 18, 2018 6:51 pm
of course...
this code are for testing a table users...
with a call to another page with javascript function...
Post by Pablo » Sat May 19, 2018 8:30 pm
I'm sorry, I cannot help you with programming.
Unfortunately I cannot teach you how to write code. That may take days or weeks.
The code you insert in a HTML object will be inserted "AS IS". So ,it's up to you ta make sure it works and does not conflict with other scripts on the page.
