serial number
tubenirvana
serial number
Post by tubenirvana » Mon Oct 30, 2017 7:02 pm
I installed a copy of Quick'n Easy on my laptop as I am traveling overseas and need to keep working. Do I need to buy another license, I already have the program running on my home pc, thanks.
Re: serial number
Post by Pablo » Mon Oct 30, 2017 9:17 pm
You can use the same license on 3 computers for your own use. The license may not be share with another user.
tubenirvana
Re: serial number
Post by tubenirvana » Tue Oct 31, 2017 2:00 am
OK, great, so how do I retrieve my serial number for version 5, I tried to use the number for version 4 but it did not work.
Re: serial number
Post by Pablo » Tue Oct 31, 2017 7:09 am
You can request your serial number here:
http://www.quickandeasywebbuilder.com/serial.html
tubenirvana
Re: serial number
Post by tubenirvana » Tue Oct 31, 2017 4:04 pm
thank you very much!
tubenirvana
Re: serial number
Post by tubenirvana » Tue Oct 31, 2017 4:35 pm
well, this must be one of those days.....
OK, so I downloaded v4 to my laptop and installed it, all good, entered the serial number, all good.
Then I copied the working file from version 5 and tried to open it in version 4, it crashes version 4. I tried reinstalling v4, still crashes the program when I try to open the work file.
Then I thought OK, I upgrade to v5. Downloaded it to my laptop, installed it, but then it asks for a serial number, and of course, v4 serial number does not work.
How to I proceed from here, thanks.
Re: serial number
Post by Pablo » Tue Oct 31, 2017 7:25 pm
You cannot open a project that was saved in version 5 in an older version. Older versions do not support the new features.
Please open one of your backups (before you saved it with version 5) or upgrade your license.
More information about backups:
http://www.quickandeasywebbuilder.com/f ... 10&t=41168
More information about upgrading:
http://quickandeasywebbuilder.com/howtoupgrade.html
