*** SOLVED *** Installation frustration
bartc
Post by bartc » Mon Nov 13, 2017 10:57 pm
please excuse me.. i am sure this has been beat to death..
i've fouled up several installations(forced to reload from DVD)
from following suggestions and workarounds to get things installed..
Linux bart-HP-Pavilion-x360-Convertible 4.13.0-16-generic #19-Ubuntu SMP Wed Oct 11 18:35:14 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Is there a Set list of prerequisite library installations necessary for a successful install?
OR
Is there a definitive installation routine/list of instructions?
This is as far as i get...
./qnewb: error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory
and no matter what or where i install this, it does not find it...
I'm totally frustrated! please help
thank you
Re: Installation frustration
Post by Pablo » Tue Nov 14, 2017 7:28 am
Did you try to use the .deb file?
Maybe this will be helpful?
bartc
Post by bartc » Tue Nov 14, 2017 1:22 pm
i finally got it running the installation files that everyone seems to be needing are
sudo dpkg -i libpng12-0_1.2.54-1ubuntu1_amd64.deb
or
sudo dpkg -i libpng12-0_1.2.54-1ubuntu1_i386.deb
Post by Pablo » Tue Nov 14, 2017 4:56 pm
Thanks for sharing your solution!
