carousel does not become responsive
nama
Post by nama » Tue Dec 12, 2017 12:07 pm
I'm installing the toolbox Carousel, but when I do the mobile test it does not work responsively.
I have changed different options but I can not get it to work correctly for mobile.
You can indicate any suggestion, or another one that works responsively.
Installation in S.O. Ubuntu 16.04
Re: carousel does not become responsive
Post by Pablo » Tue Dec 12, 2017 12:17 pm
Did you check out the example templates? Many of them are using a responsive Carousel:
http://quickandeasywebbuilder.com/templates0.html
nama
Post by nama » Tue Dec 12, 2017 7:52 pm
thanks for your fast answer
nama
Post by nama » Tue Dec 12, 2017 7:59 pm
I have tried the template works and when I open the program quickandeasywebbuilder is lost.
Post by Pablo » Wed Dec 13, 2017 8:37 am
What exactly do you mean by this?
Can you please be more specific?
nama
Post by nama » Wed Dec 13, 2017 6:04 pm
When I try to open the template name woks.
the program disappears.
I've tried it several times and that always happens.
I do not know if I'm doing something wrong.
Post by mexman » Wed Dec 13, 2017 10:27 pm
Hi NAMA:
You should download the template to your computer and then unzip the file and open it with QnEWB. So obviously QnEWB is already open when you see the template!
Therefore this: "when I open the program quickandeasywebbuilder is lost" cannot be understood!
BTW:
You cannot OPEN the template but select "New File from Template". Then you can PREVIEW and use the template.
Are you using a licensed version of QnEWB?
Which Version?
Which template?
What are the exact steps you are doing?
Post by Pablo » Thu Dec 14, 2017 7:16 am
See also:
http://quickandeasywebbuilder.com/using_templates.html
Note that new templates can only be opened in the latest version.
nama
Post by nama » Thu Dec 14, 2017 9:46 pm
Hello and thanks for the help and the contributions.
I have done the test again and the problem is in the template "Works".
When you call the template "Works" - File / New Web Site from Template ... - qewb closes.
In order to use qewb it is necessary to delete the "Works" template from the "Templates" folder
QEWB version 5.2.2 for Ubuntu
Current payment license
SO Ubuntu 16.04
Nama
Post by Pablo » Fri Dec 15, 2017 7:13 am
On my test computers the works template does not cause any problems.
I could not find your order based on your name or email address.
What is your order number?
nama
Post by nama » Fri Dec 15, 2017 8:57 am
Where did I send the order number?
Post by Pablo » Fri Dec 15, 2017 2:11 pm
When you bought your license you have received an order number from the reseller. You will find it in the subject of the confirmation email.
vev
Post by vev » Fri Dec 15, 2017 3:10 pm
Hi, Pablo,
Nama's license is from my license number.
The license is installed on two PCs.
You have registered my company data.
If you need me to send you some information, indicate your direct email.
The problem of the template "Works" occurs in 2 PCs.
Post by Pablo » Fri Dec 15, 2017 6:29 pm
Please note that you are not allowed to share a license. A license is for one user only.
I have tested the works palette on 5 different computers and found no issues.
If you want my support then I need to know your order number.
vev
Post by vev » Fri Dec 15, 2017 8:09 pm
Note:
Only one person "Nama" works with a desktop PC.
The other installation is in a portable pc and only to check situations like the "Works" template and in case the desktop PC breaks.
We also have a previous version on an external hard drive for old websites.
The 3 installations Ubuntu 16.04 LTS
Am I doing the right thing with the license?
The motive of two users in the forum:
I start working with your program, but now this work is done only by "Nama". I only help when strange situations appear.
