Layers and Layout Grids
ybman
Post by ybman » Fri Jan 19, 2018 2:10 am
Hello Pablo, I was trying to set up my site with Layers with Layout Grids.
The layout grids keep wanting to go right up over the layer.. Could you help please?
ybman
Re: Layers and Layout Grids
Post by Pablo » Fri Jan 19, 2018 7:19 am
This is normal behavior. Layout grids are floating (not absolute positioned) so they float from the top to the bottom, otherwise they would not be flexible.
Related tutorial:
http://quickandeasywebbuilder.com/layoutgrid_part1.html
Relate FAQ:
viewtopic.php?f=10&t=43910
ybman
Post by ybman » Sat Jan 20, 2018 4:34 pm
Hey Pablo, I am trying to make a site with Layers and Layout Grids on the same page?
Do you have any examples or templates..?
** Cause, when I put a layer one the page and then put a layout grid on.. The layout grid goes over the layer.. How can I do this..
Thanks.
Post by Pablo » Sat Jan 20, 2018 6:13 pm
ybman
Post by ybman » Sun Jan 21, 2018 6:01 am
Hello Pablo,
I greatly appreciate your work and time..
** Just curious, if you have any examples of where you put a layer, layout grid and then another layer.
Post by Pablo » Sun Jan 21, 2018 8:28 am
Most of the templates use a combination of layers and layout grids.
Make sure the layer is set to 'floating'.
ybman
Post by ybman » Wed Jan 24, 2018 12:42 am
Hello Pablo,
I have been trying to figure out how to make a responsive site with a box such as the one below..
** I want an image(with a box/text towards the bottom of image)
** and when the screen gets smaller.. The box with text doesn't come disconnected from image; which is what is happening now...
The is from another site, but is what I am trying to get to..
https://drive.google.com/open?id=1ac2y2 ... AjuZz5fFwm
I couldn't get the image in the post.. Here is the link to the screenshot..
Thanks for your help..
Donald
Post by Pablo » Wed Jan 24, 2018 7:20 am
Did you try the 'Features with images' block in the Block Manager?
Or else you can use flexbox and give the text its own alignment at the end of the box.
