64bit for 10.14 OSX
warmup
64bit for 10.14 OSX
Post by warmup » Fri Jan 26, 2018 4:42 pm
In autumn the next osx 10.14 doesn´t support 32bit-Apps.
I´m using Quick´n Easy Web 4.0 which will be supported any more.
Is V5 64bit-Ready or is there a plan to make Quick´n Easy Web 64bit-ready?
Re: 64bit for 10.14 OSX
Post by Pablo » Fri Jan 26, 2018 6:02 pm
A 64bit version is planned for the next version. Hopefully it will be ready before autumn 2018.
