text editing and page lenght
fritsmartfu
Post by fritsmartfu » Fri Feb 09, 2018 10:08 am
On a website I made a master frame 670 wide x 450 height. To that master frame I linked a scroll-able page what I filled with a copied .txt file. The total length of the text is (to the property manager) more then 1500. Only the first 800 become visible with the editor scroll function. The remaining text is not editable/format-table, because of not visible! Previewing the result shows the whole text (regulations) scroll-able, formatted and the not formatted part.
Question: how to get the whole text editable, or, is there a text/word program to pre-format the text and to copy into the editor frame?
Thank you!
As a Dutchman we live already 30 years in Hungary.
We like te help the local community in there developement, but in many fields (specially for computer use and website constructions) I need help myself.
Re: text editing and page lenght
Post by Pablo » Fri Feb 09, 2018 6:35 pm
Maybe you will need to increase the height of the page?
fritsmartfu
Post by fritsmartfu » Sat Feb 10, 2018 1:35 pm
Thank you! That is the solution!
Last question: How to finish this item? Is there a button to finish or stops this item automatically?
Post by Pablo » Sat Feb 10, 2018 6:32 pm
Do you mean the forum topic?
Some users mark it as ** SOLVED *** in the title.
fritsmartfu
Re: text editing and page lenght **SOLVED**
Post by fritsmartfu » Sun Feb 11, 2018 6:16 pm
Thank you, Pablo!
Users browsing this forum: No registered users and 3 guests
