videoPlayer for iphone
sirco
Post by sirco » Sat Mar 31, 2018 8:46 pm
Hello,
I have a video on a web page (format .mp4 and .mov) which shows correctly on Mac, PC, Androïd (using Type=FlashPlayer and Enable HTML5=True in the MediaPlayer), but freezes on iPhone!
I tried all the types given in the MediaPlayer without success!
Any idea?
Pascal
Re: videoPlayer for iphone
Post by Pablo » Sat Mar 31, 2018 8:48 pm
The iPhone does not support Flash.
You will need to use the standard HTML5 video player, format mp4. That should work on all (modern) platforms.
Also make sure the filename is web safe:
viewtopic.php?f=10&t=131
sirco
Post by sirco » Sun Apr 01, 2018 9:45 am
Thanks for the answer.
I will see what's going to happen following your advices.
Meanwhile, I wish you a very Happy Easter!
Pascal
sirco
Post by sirco » Sun Apr 01, 2018 10:02 am
Surprising!
With HTML5 video player it works for iPhone5 (safari, firefox, chrome), but... still freezing on iPhone6!
I will have a look to the conversion of the mp4 file.
Pascal
Post by Pablo » Sun Apr 01, 2018 12:45 pm
Note that the player is standard HTML/browser functionality. It is not implemented in the software.
So, if the video does not work then the format may not be compatible with the device.
