Adding code to a website
ekdesigns
Post by ekdesigns » Sat Apr 28, 2018 8:08 pm
Hiya,
I found a nice bit of code for a cookie consent (I know there is one for this software but I wasn't sure how customised I could get it to match a website I'm recreating) - but the instructions are to place it before the </head> tag - I've tried a few of the options on 'insert html' and nothing seems to be appearing. I tested it out on another software and it appears fine so I must be doing something wrong.. Or perhaps it wouldn't be supported?
Here's the code:
<link rel="stylesheet" type="text/css" href="//cdnjs.cloudflare.com/ajax/libs/cookieconsent2/3.0.3/cookieconsent.min.css" />
<script src="//cdnjs.cloudflare.com/ajax/libs/cookieconsent2/3.0.3/cookieconsent.min.js"></script>
<script>
window.addEventListener("load", function(){
window.cookieconsent.initialise({
"palette": {
"popup": {
"background": "#232323"
"button": {
"background": "#f4cc22"
"content": {
"message": "We use cookies to track usage and preferences.",
"dismiss": "I Understand",
"link": "Privacy Policy",
"href": "http://www.malcolmdown.co.uk/privacypolicy.html"
</script>
Many thanks!
Esther
Re: Adding code to a website
Post by Pablo » Sat Apr 28, 2018 8:35 pm
You can place this code between the head tags in Page HTML.
The code will be inserted "AS IS", so it will work the same as with other software.
Note that because the 'https' prefix is missing in the css/script references, this code will only work online.
ekdesigns
Post by ekdesigns » Sun Apr 29, 2018 3:58 pm
Yes I thought as much, but unfortunately even after I put the code in that location and also publish it, it's still not appearing. I did get it to work briefly when I discovered another version of the code was also in the 'inside <html> tag' part but when I got rid of that, it never appeared again! Must be missing something..
Here's where I published it: http://www.ekdesigns.co.uk/demo/
Thanks,
Esther
Post by Pablo » Mon Apr 30, 2018 5:53 am
It seems to work correct for me.
Maybe you have clicked 'I Understand' and it will never be displayed again?
Post by mexman » Fri May 04, 2018 4:08 am
Esther:
It is not working here, because you inserted PHP code into teh demo page without changing its extension to "PHP"
