quiz with showing results
chainho
Post by chainho » Tue May 08, 2018 6:17 pm
Hi Pablo. Is there a way to implement a quizz with showing results? i tried to do it using code i´ve searched on internet but without success.
Thanks.
Jorge Chaínho
Re: quiz with showing results
Post by Pablo » Tue May 08, 2018 8:45 pm
There is no standard solution for this. This will require programming.
You can (visually) create the layout with the form tools but the 'logic' must be implemented with scripts.
or you can look for a third part script and use the HTML object to integrate it into your website.
chainho
Post by chainho » Thu May 10, 2018 5:54 pm
Thanks Pablo. I finally did it.
Best regards.
Jorge Chaínho
