Program folder on a MAC
tubenirvana
Post by tubenirvana »
in which folder, and where, does the program hold all its files and folders etc on a MAC. It is easy enough to find the program folder on Windows, but I can't seem to find it on my MAC, thanks.
Re: Program folder on a MAC
Username/Library/Application Support/Quick 'n Easy Web Builder 5/
or
Username/Library/Containers/com.pablosoftwaresolutions.quickandeasywebuilder/Data/Library/Application Support/Quick 'n Easy Web Builder 5/
tubenirvana
excellent, thank you!
