Scroll bar didn't showed-up on smartphone
wingo
Post by wingo »
Hi
I have an object link to a page in the same project, that I what to display in lightbox
On PC's, everything's fine with the scrollbars displayed well onto the lightbox :P ,
.... but on smartphone & tablets, the scroll bar didn't appear at all :cry: ... so users can also see partially the page (in the limits of width/heigh) defined in the ligthbox setting. But they can't scroll down see everthing
Thanks for your help
Re: Scroll bar didn't showed-up on smartphone
Most mobile browsers (like the iPad/iPhone) do no support multiple scroll bars inside the page (besides the ones of the page itself).
As far as I know there is no workaround for this.
