quickmenu font size
johnvanhulst
quickmenu font size
Post by johnvanhulst » Mon Jun 11, 2018 11:09 am
Hi, can anybody tell if it is possible to change the font size of the quickmenu drop-down list of menu items? I do not mean the font size of the text button, you can change that. The font size seems to be 8 pixels or something like that, which is far to small to be used on a mobile phone or a tablet for finger-touch selection of the drop-down list of menu items... Thanks in advance, John van Hulst
Re: quickmenu font size
Post by Pablo » Mon Jun 11, 2018 8:31 pm
The font-size property affects all items of the menu.
Note however that it is up to the browser to render the control (select /combobox) , so it may look different in other browsers.
johnvanhulst
Post by johnvanhulst » Tue Jun 12, 2018 12:14 pm
Thanks for your answer Pablo. And what I was saying isn't correct indeed. I watched the drop-down list in a resized browser on my laptop. Now that I looked at it on my mobile, I noticed the font size is OK!
