is Possible the implementation of Text object
vic53
Post by vic53 » Thu Jun 14, 2018 7:51 pm
Hello Pablo
your editor is a great program, I ask you
is possible the implementation on the object "Text" to stop the conversion of the CHAR "<" and "> as this?
<div><span style="color:#0000CD;">&lt;?php echo $descrizione;?&gt;</span></div>
in
<div><span style="color:#0000CD;"><?php echo $descrizione;?></span></div>
in order to remain the code as I wrote on that line...?
this will be good also for other objects as for example the object "Image"?
un saluto dall'Italia e da un tuo fan..
ciao
Vincenzo Manarolla
thanks a lot.
Re: is Possible the implementation of Text object
Post by Pablo » Thu Jun 14, 2018 8:38 pm
Text -> Object properties -> Do not encode HTML characters.
vic53
Post by vic53 » Sat Jun 16, 2018 10:25 am
ok, then I need to use the HTML object for dynamic text …. is it ok?
therefor this wants a lot of property to build the text in the html but i can to use the class in the CSS style...
Post by Pablo » Sat Jun 16, 2018 10:55 am
Did you try my suggestion?
