errior on viewing html layout
vic53
Post by vic53 » Sun Jun 17, 2018 9:04 am
the code output from web builder write this code
<head>
<meta charset="utf-8">
but the display output is wrong when displaying Char "è à ' ò ù" in the form output...
I verify that the correct code to display correct the output html is
<meta http-equiv="Content-Type" content=\"text/html; charset=UTF-8\" >
in this mode the display is correct but if I insert this line of code in the builder, the builder make the substitution of my correct line of code with that incorrect code
I think that this is an error and the line above is the correct code
thanks if you make the correction…
Ciao
Vincenzo M.
vic53
Re: errior on viewing html layout
Post by vic53 » Sun Jun 17, 2018 9:55 am
an other information is that the error is when using HTML5 on the page…
using the output code of the builder the display is wrong but with that correction the display is Ok…
using the format for HTML4 the result is wrong with that line of code but now all use HTML5.
Post by Pablo » Mon Jun 18, 2018 5:57 am
This is not an error. The code is correct for HTML5
https://www.w3schools.com/Html/html_charset.asp
So, if it does not work then there is most likely another reason for it.
vic53
Post by vic53 » Wed Jul 04, 2018 7:44 am
ok
thanks
