Linux Mint 19 installation
askwara
Post by askwara » Fri Sep 07, 2018 10:53 pm
Hi, I installed QnEWB 5 on my new Linux Mint 19, MATE, 64-bit.
The menu shows icon but it does not respond. Also, I clikc qnewb on downloaded file and nothing happens - cannot start program. I never had such problems on older versions of Mint and Ubuntu.
What could be the reason and solution?
Thanks,
Alex
Re: Linux Mint 19 installation
Post by Pablo » Sat Sep 08, 2018 7:10 am
If the application will not start then this means that libraries are missing.
See this related FAQ:
viewtopic.php?f=10&t=40319
See also:
viewtopic.php?f=5&t=44883
askwara
Post by askwara » Sun Sep 09, 2018 3:21 pm
Thank you!
The second link was helpful.
Alex
