File Publisher, file location
Post by mexman »
Hi Pablo:
When I use the file publisher....does it move the files into the project directory (same as images) before publishing or do they stay locally on my computer where they were located before using them in QnEWB?
Re: File Publisher, file location
The files will be moved to the project folder, unless you disable Asset Management in preferences.
Post by mexman »
Thanks for the quick answer!
