I have a jpg in a galery...the thumbnail shows up, but when I click on it for an enlargement, I get "The requested content cannot be loaded.
Please try again later.". What could be the cause here?
The requested content cannot be loaded. Please try again later.
Re: The requested content cannot be loaded. Please try again later.
Maybe the filename of the image is not valid/web safe?
http://www.quickandeasywebbuilder.com/f ... f=10&t=131
the filename is animaplakat.jpg, so I don't think it's a filename issue.
What is the URL of the page, so I can see at you have done?
Are you sure that this image is on the server?
Did you publish all files?
I cannot even open the image using a direct link:
http://rejdaabt.com/images/animaplakat.jpg
So, this is not directly related to the gallery.
Thank you, you've solved the issue. I hadn't published the website properly.
