tabbed choice of html5 audio player
kgnoble
Post by kgnoble »
Hi
I would like to be able to have the user flick between tabs to link to two separate players with separate play lists. I do not seem to be able to have two independent players on the same page; when I try, they default to the same play list.
http://www.evemusic.co.uk./index.php#c1 is what I have at present.
Any way of implementing this with perhaps tabs or carousel or some other method?
Many thanks
Keith
Re: tabbed choice of html5 audio player
I'm sorry, the player was designed to be used once per page.
To support multiple players you will have to implement your own code or use a third party script.
kgnoble
Post by kgnoble »
Ah!
OK - thanks for letting me know.
K
kgnoble
Post by kgnoble »
A further thought on this. I seem to be able to run two separate pages with a player on each and with their own playlist. However, I cannot see how to stop the player playing when the page is left. Am I missing anything or is there a need for extra code?
Many thanks
Keith
The browser should automatically stop the audio when you leave the page.
Maybe you have opened the page in a new window, so the other page is still in the background?
Note there there is no support on extensions. They are provided "AS IS".
