Qnewb 6 64 bit on Fedora Linux
dmontaine
Post by dmontaine »
Fontawesome does not install automatically. Has to be manually insalled using:
sudo dnf install fontawesome-fonts.noarch
Starting Qnewb from command line - a couple of non-fatal errors are thrown:
[don@localhost Qnewb]$ ./qnewb
*** BUG ***
In pixman_region32_init_rect: Invalid rectangle passed
Set a breakpoint on '_pixman_log_error' to debug
(qnewb:2293): Gtk-CRITICAL **: 02:17:15.683: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkScrollbar
Re: Qnewb 6 64 bit on Fedora Linux
Maybe the application does not have permissions to install fonts on your system?
