Trying to play with FlexBox Container
Post by mexman » Thu Oct 11, 2018 7:54 pm
Trying to get things done with Flex Container:
Which object(s) can be sent into a FlexBox?
Seems that every TEXT and every IMAGE is a Flexbox. LAYERS seem not to be possible.
Seems that only ONE object goes into a FlexBox.
Is that correct?
Re: Trying to play with FlexBox Container
Post by Pablo » Thu Oct 11, 2018 8:25 pm
A flexbox container can only contain flexible objects.
A layer is a (fixed/absolute) container so it cannot be used with flexbox.
Flexbox is basically a modern way of aligning elements, so it was designed for multiple elements.
Related tutorial:
http://quickandeasywebbuilder.com/flexbox.html
