Slick Layout
Toadoline
Slick Layout
Post by Toadoline » Fri Oct 12, 2018 9:59 am
Can anybody give me some steer as to how I can create a page that behaves like this one on the BBC news site?
https://www.bbc.co.uk/news/resources/id ... _Chernobyl
Just a few points to get me started would be really helpful.
Re: Slick Layout
Post by mexman » Fri Oct 12, 2018 12:08 pm
Which part do you refer to?
The navigation? The responsive design?
You can find several similar working templates on the web site.
Toadoline
Re: Slick Layout
Post by Toadoline » Fri Oct 12, 2018 4:53 pm
The responsive design - I thnk, if that describes the way the page background changes and the foreground scrolls.
Which template is similar - can you point me to it.
Many thanks.
Re: Slick Layout
Post by Pablo » Fri Oct 12, 2018 5:17 pm
You can duplicate this with layers /layout grids and the background size set to 'fixed' or 'parallax'
http://quickandeasywebbuilder.com/parallax.html
Toadoline
Re: Slick Layout
Post by Toadoline » Sun Oct 14, 2018 10:45 am
Many thanks.
