High DPI Support
Magin
High DPI Support
Post by Magin »
Good afternoon Pablo,
I would like to know why this version does not have the high dpi support, the previous versions, before automatically when the application was opened, it enabled this support automatically and with version 6 it has disappeared :|
Thank you very much. Rafael.
Re: High DPI Support
The DPI behavior should be the same as in previous versions. Nothing has changed related to this as far as I now.
Which platform are you using?
If you are using Windows then maybe you have used different compatibility options?
