just installed the program and followed instructions found here but it still doesn't start
***solved***Quick 'n Easy Web Builder 6 doesn't start on Ubuntu 18:04
Re: Quick 'n Easy Web Builder 6 doesn't start on Ubuntu 18:04
Did you install the correct version for your platform? 64bit/32bit?
Did you use the Debian package?
Hi, tnxforyour reply.
I installed the correct version 64bit. I downloaded the file from the link provided by email.
How do I run the program from the terminal?
If you use the Debian package then an icon will be added to your application menu.
If you unzip the files manually then you can double click the executable (qnewb) or type the name of the application in a terminal.
Hi Poulou:
I am using QnEWB with Ubuntu 18.04 without any problem. Use the .deb file to install! I did not have any problem!
I didn't see there was a .deb file. I just installed from the link provided in the email.
So I installed now the .deb file with gdebi and the program started immediately.
Thanks for your help.
philippe
philippe
