Missing api-ms-win-crt
Timkay
Post by Timkay »
Trying to install Q'n'E on a clean installation of Windows 7 64 bit. It installs OK and then won't run, pops a window up:
The procedure entry point ucrtbase could not be located in the dynamic link library api-ms-win-crt-convert-l1-1-0.dll
I have never seen this before.
I found the DLL, downloaded it and put it in Windows/system and windows/system32 and in the root directory of Q'n'E. Tried a reboot of the computer. Still have the same problem.
Any ideas please?
Tim
Re: Missing api-ms-win-crt
If the 64bit version does not start then your system probably needs the Visual C++ Redistributable Packages install run-time components.
https://www.microsoft.com/en-us/downloa ... x?id=48145
Timkay
Post by Timkay »
As usual, you are correct - 10 second download and all is working eprfectly.
Thank you
Tim
