How to download and open trial version on Mac
ec55
Post by ec55 »
I have downloaded the trial version for Mac.
When I open it with default DISKIMAGE MOUNTER a window opens that shows the icon but then it ask to show in new window - or open contents = but nowhere do I see sn app installer what eventually happens is that the program just opens up!
You had mentioned something about somehow putting it in app folder - how to do that?
Usually Mac will open that up automatically and you slide the icon of new program into that position as you probably know.
Suggestions please?
Re: How to download and open trial version on Mac
There is no installer, you can directly drag & drop the icon to your applications (or anywhere else).
See also:
http://quickandeasywebbuilder.com/firststeps.html
