Centre Browser 'grayed out'
DoctorWeb
Post by DoctorWeb »
Ive got some pages on several sites that have the
'Center in web browser' option (2nd item down in Property Inspector)
grayed out - i.e. there is no way to select it.
I have looked at all other charactertistics and cant find anything i have set wrong.
i notice that these images when viewed ina browser , via the server, wobble from side to side as you touch them,
Probbably some silly 'on or off' adjustment, but I cnat find whwere its controlled.
thanks
Re: Centre Browser 'grayed out'
"Center in browser' will be disabled if you select "Use 100% page width/height"
