Searchresults and Inline-Frame
Blitzer
Post by Blitzer »
after the version change to 6.0.4 my old problem is back.
I use inline frames. The results of the search function are displayed in the inline frame. A click on the results unfortunately opens a new page.
In generated file "sitesearch1-results.html" I changed from "_parent" to "_self". Unfortunately, no success.
See "My website with frames"
http://www.quickandeasywebbuilder.com/f ... 13#p212992
Rolf
Blitzer
Re: Searchresults and Inline-Frame
Post by Blitzer »
Everything on zero ...
Of course, the new tutorials also belong to the new version 6.x.
The subitem Target must be set to -self.
Thx
Blitzer
To be able to help you, I need your project file.
See also this related FAQ:
Blitzer
Post by Blitzer »
The problem is solved, the solution was to switch from _parent to _self, so that the results are displayed in the inline window.
@Pablo: Thanks for the offer to help.
Blitzer
