HTML5 or HTML 4.01 Trans
dchaley369
Post by dchaley369 »
Pablo, In your opinion should we be using HTML5 or HTML 4.01 Trans formats.
Chris
Re: HTML5 or HTML 4.01 Trans
HTML5 is now supported by all modern browsers, so that is the best choice.
Unless you have added custom code to the page which does not work with HTML5.
