Version 6.1.0 does not start under Linux Mint 18.3 Cinnanon 64-bit
Re: Version 6.1.0 does not start under Linux Mint 18.3 Cinnanon 64-bit
Post by betwixt » Thu Mar 07, 2019 8:13 pm
This won't fix it but it might give us some clues:
Open a terminal window.
Type: cd 'Quick and Easy Web Builder' (or wherever you have stored it)
Type: ls -al Q*
Then tell us what is displayed. My system is using Kubuntu 18.10 and it works fine for me, my screen shows this:
-rwxrwxr-x 1 brian brian 36993176 Feb 5 09:04 qnewb
-rw-r--r-- 1 brian brian 158 Jul 28 2016 qnewb.desktop
-rw-r--r-- 1 brian brian 3990774 Jul 9 2018 qnewb.pdf
the dates may be different on yours but the execution bits and sizes should be the same.
yngand
Post by yngand » Thu Mar 07, 2019 8:54 pm
Hi Brian!
Version 6
yngve @ abras06 / opt / quick-n-easy-web-builder-6 $ ls -all q *
-rwxr-xr-x 1 root root 36993040 Feb 5 11:12 qnewb
-rw-r - r-- 1 root root 158 Jul 28 2016 qnewb.desktop
-rw-r - r-- 1 root root 3990774 jul 9 2018 qnewb.pdf
Version 5
yngve @ abras06 / opt / quick-n-easy-web-builder-5 $ ls -all q *
-rwxr-xr-x 1 root root 23524264 mar 5 2018 qnewb
-rw-r - r-- 1 root root 4492205 Sep 27 2017 qnewb.pdf
Both versions are the same but for your example for the file "qnewb" there is no "w"
Sincerely / Yngve
Post by Pablo » Thu Mar 07, 2019 9:06 pm
Did you right click the application and make sure it can be executed?
yngand
Post by yngand » Thu Mar 07, 2019 10:00 pm
When I click on the file "qnewb" I get the choice to "make executable and run" and click on it.
I have repeatedly done this without effect! The same box gives the choice "Unknown file type"
/ Yngve
Post by Pablo » Fri Mar 08, 2019 7:00 am
I'm sorry, I cannot think of anything else.
yngand
Post by yngand » Fri Mar 08, 2019 7:34 am
Ok I understand Pablo!
A big thank you to everyone who has made suggestions and commitment to my problem.
If I find out later what the problem is, I will write about this.
And now I have to continue working on version 5!
Sincerely / Yngve
Post by betwixt » Fri Mar 08, 2019 9:18 pm
Question for Pablo:
on my version the application 'qnewb' is 36993176 byte long but in Yngand's version it is 36993040 bytes.
So my working copy is 136 bytes bigger. Is this indicating a problem or does the file size depend on registration information being added to it?
Post by Pablo » Fri Mar 08, 2019 9:36 pm
No, it's not related to the registered version.
But, maybe the difference is 64bit vs 32bit.
