Range Text left AND right on same line
DoctorWeb
Post by DoctorWeb »
I need to present text in a box on a page with left AND right justify
Its songs ranged left, then a gap, which in print I do by the TAB key, which causes the next bit to range right.
the listing is simply Song and artiste
e.g.
Revolution BEATLES
Sympathy for the Devil ROLLING STONES
I did that using space 'characters'
but it takes forever,and looks messy,
(even more so when I want it to be responsive!)
Ive soucred the Help document and this forum, to no avail; it just dances me towards TABS as in page menus.
Has anyone any idea how I can acghieve this in QnE WB? v5 pref.
(Ive bought v6 but am still on all v5 as my sites all fall over when I use the v6 )
Re: Range Text left AND right on same line
Post by mexman »
Hi DoctorWeb:
This is not possible... nothing to do with QnEWB. It is just not possible in HTML.
You should use a TABLE to do so!
You sould use cellspacing = 0 and border width = 0 so the cells are not visible as such, just the tabbed text.
mexman is right, HTML does not support tabs
If you have a flexible layout then you can also use a layout grid to create text columns.
DoctorWeb
Post by DoctorWeb »
OK, Thanks Guys, I appreciate your help.
(I shall go aand try and learn to make a table now!)
DoctorWeb
Post by DoctorWeb »
Pable said:
"If you have a flexible layout then you can also use a layout grid to create text columns."
Im not sure what a flaexible layout is. Is this a technical term,. o
or do you mean am I flexible on how the page looks?
I need to make quite lengthy lists of 'Song and artiste'
but that apart its quite flexible.
I did check the tutorials but saw nothing that would do anything like that, or described as 'flexible'.
Im not sure what a flexible layout is. Is this a technical term,. o
Please see this related tutorial:
http://quickandeasywebbuilder.com/layout_modes.html
Then I recommend to use layout grids, so the layout is easier to manage.
