Recent files disappeared from the list in the "files" tab
sbrantes
Post by sbrantes »
Previous versions of Quick'n easy web builder had the ability to keep a large number of recently opened files at the end of the "files" tab.
I could not find that function in version 6 for mac. It was very useful because it made updating multiple sites more agile.
How could we restore that function?
Thanks !!!
Re: Recent files disappeared from the list in the "files" tab
This feature has not been removed.
However, this functionality is not available in the sandboxed Mac version (from the App Store), because in that case the software does not have direct access to the file system.
sbrantes
Post by sbrantes »
Thanks, Pablo
then I will go back to the downloadable version on your site. I had switched to macstore only for comfort for upgrades.
Best regards
