Inline Frame responsive?
Post by mexman »
I could not find "Inline Frame" in the list of non-responsive objects, but seems it is not!
Am I missing some adjustment or does it really not behave like responsive for the related contents?
Edit: Oh, just saw I can achieve this performance (somehow) with Lightbox=true. -> New question: Can I trigger the lightbox opening via a link also or only by clicking the "preview picture"?
Re: Inline Frame responsive?
An inline frame is responsive, it is a standard HTML feature.
Note however that the size of the inline frame determines which breakpoints you will need to add to embedded page.
Yes, you can trigger a lightbox via a link. Set the target of the link to 'open in a lightbox'
The lightbox type can be configured in the page properties.
More lightboxes:
http://quickandeasywebbuilder.com/lightboxes.html
Post by mexman »
Maybe I did not express myself well:
"An inline frame is responsive, it is a standard HTML feature."
The inline frame itself......maybe.
But if I put the Inline Frame into a e.g. Layout Grid, it does not adjust responsively to the screen size, only to the differente breakpoints.
Maybe you meant 'flexible' instead of 'responsive'?
Did you set the 'full width' property of the inline frame to 'true'?
