I notice the Compatibilty for Safari mobile background fix setting on the main page, seem to change by it self from True to false, when editing the main page? Is this normal? So I have to make sure I check it before publishing. It does not happen all the time though?
I'm using the 'generic' Linux version which doesn't have the image as a file.
Sorry for being a thief but I copied the one from your reply as an image and added that instead. It works!
