QaEW and Boxcryptor
warmup
QaEW and Boxcryptor
Post by warmup »
I´m using QaEW 6.1.1 on my macOS 10.14.4.
My Homepage-Projects lying on the iCloud in an Boxcryptor-Folder (Version 2.27.977).
If I try to save an edited project QaEW freeze and the QWB-File will be destroyed!
Re: QaEW and Boxcryptor
I'm sorry, I am not familiar with Boxcryptor. But note that saving files is standard system behavior over which I have no control.
For the software does not know anything about Boxcryptor or how files are stored it just uses the standard file functionality of the system.
Boxcryptor probably intercepts this functionality to do its work in the background.
