PayPal button issues
tubenirvana
Post by tubenirvana »
I have been using the PayPal button on my web site for quite a while, but suddenly, for no apparent reasons, some of the PayPal buttons, when clicked on, instead of sending the buyer to their PayPal page for purchasing, it actually opens up a new e-mail window showing the following:
business=example@gmail.com
cmd=_xclick
item_name=1:1IsolXfmr
item_number=1:1IsolXfmr
amount=15.00
currency_code=USD
shipping=
shipping2=
handling=
return=
cancel_return=
undefined_quantity=0
receiver_email=example@gmail.com
no_shipping=0
no_note=1
submit.x=83
submit.y=25
As far as I can see, all the PayPal buttons, apart from the item description and price, have identical setups.
No matter how often I delete the PayPal button in question and place a new PayPal button on the page, I cannot get it to go to the PayPal page.
The web page in question is here, it is the PayPal button right at the bottom of the page, http://www.erhard-audio.com/AutoBias.html
Re: PayPal button issues
It looks like you have placed the PayPal button inside another form?
A PayPal button should not be inside a form because the button itself is already a form.
HTML does not support nested forms.
Note: if you are asking for help then please disable all HTML formatting/beautify options otherwise I cannot see the code.
tubenirvana
OK,
I will check that.
As to HTML formatting/beautify mode...I have no clue what that is so as far as I know I did not enable it unless it is so by default?
tubenirvana
OK,
it looks like I have used the wrong kind of 'form' to create a centered text & photo area.
If you have a look at the web site, you will notice that most pages have two colors. The main 'overall' background color then a smaller width second background/box where all the text etc is located.
I used a 'form' to create that second background/box, which is obviously the issue here.
So how do I create this second background/box area with a different color to place all the text etc in it.
I have been looking and trying different things bit so far have not been able to figure out how to create the text area with a different color and smaller width, thanks.
Instead of a form you can use layer or shape to create a background section.
I think you should try a shape first.
tubenirvana
OK,
I figured that out late last night, but I cannot seem to center it in the page.
I direct it to get centered, but in preview and after I uploaded a test page it is left margin. No matter what I try I cannot center the shape on the page.
Maybe you did not center it relative to the page width?
it should work the same as a form/layer.
Note that I cannot see what you have done based on the HTML code only.
To be able to help you I need a copy of the (stripped) project file.
See also this related FAQ:
tubenirvana
I used the Arrange menu then Center In Page, I tried, both, vertical or horizontal. It worked when I use forms, but does not do it when I use layer or shape.
In the wysiwyg window it looks centered, but when I preview it and upload it it is left margin.
I strictly use menu functions as provided by the program, I never try and override or use my own HTML code.
tubenirvana
I just sent you an e-mail message giving you a link where a stripped down version of my work file can be downloaded from
Thanks for sharing the file.
The 'Center in browser' property is set to 'false', this should be 'true'
tubenirvana
thank you!!!
son of a gun!!!....the simplest thing and I looked all over!
Now its all good! :-)
