Hi
When using the Photo Gallery object there are 2 issues.
1) Thumbnail Size argument: Does not work when selecting an option via the mouse always goes back to "responsive", Workaround is to use the arrow keys
2) Frame Style argument: When selecting any of the Box Shadow options the following error occurs.
Failed to load Image from file ""
Cannot open file *error2: the system cannot find the specified.)
Dean
Photo Gallery QnEWB V.6.2.0 64Bit
Re: Photo Gallery QnEWB V.6.2.0 64Bit
Thank you for the information.
Which platform are you running the software on?
As far as I know there is no 'Box Shadow' frame style in the Photo Gallery.
Hi.
Running on windows 10. i5 16gb ram.
The box shadow shows in the list for the frame style of the photo gallery.
Dean
Dean
The 'box shadow' options should not be there.
This is most likely an error in the setup. I will remove the invalid entries in the next update.
