Hi
Is there or will there be an option to add a verical and/or horizontal scroll for the data section of the JQuery Tabs object
I am putting a a photogallery in the tab. I cannot find a scroll on the photo Gallery either.
Dean
JQuery Tabs Scroll
Re: JQuery Tabs Scroll
I'm sorry, there are currently no plans to implement this functionality because this will most likely not work on mobile devices.
But maybe you can use an inline frame to display the gallery?
Hi.
Thanks for the reply. Going to use jQuery Accordian on 320px option and see how that works.
Dean
Dean
