My new site and some little issues
psaldari
Post by psaldari »
Hello, finally I have published my new site. It is based on the basic-template6 (thank you Pablo) and I am very happy with it, it's not totally finished an perfect but now I have a modern site.
OK, my first little issue are related to the Sticky-layer and the footer.
I have create a master page with the header, the footer, the Sticky-layer and the affix header. All the site pages are related to this master page
In some pages like the home page:
http://www.aprisogni.it
when I scroll the page down, the Sticky-layer stay over the footer, and it's OK.
But in some other pages, like this:
http://www.aprisogni.it/organizzazione/ ... a2019.html
the Sticky-layer goes under the footer and I can't understand why.
Second little issue is:
If I see the home page on my iPhone SE I can scroll the page on vertical (an its OK) but also in horizontal (not good) because there is a white space on the right.
I see if on my project there is something hided but and I don't have found nothing suspect.
Well, thank's in advance to anyone can help me.
Paolo
Re: My new site and some little issues
Did you try: Arrange -> Move to front?
The image with ID: 'contattaci' has a fixed size ,
set 'full width' to true to make it flexible.
psaldari
Post by psaldari »
Hello Pablo,
yes, I try to move to front but nothing... this thing is on the master page, and its not selectable on the normal pages. The strange behavior is that in some pages works like expected and in some others no, but all the pages are made with the same master page :shock: I do not know what to think...
psaldari
Post by psaldari »
Thank you, this is it...
Its a text box published as image, in the property inspector there is no possibility to set the full width. There is another way?
Thank's
Paolo
The problem is related to the order of the objects on the page. So , you will have to check what is the difference between the pages.
Note that I cannot see exactly what you have done based on the HTML code only.
I'm sorry, a textbox publish as image cannot be full width.
psaldari
Post by psaldari »
OK, I have reduced the right column where there is the "contattaci" image problem, and the issue is not totally resolved and not perfect but much better.
For the Sticky-layer issue... its not a big deal, for now I have more pages to do and a lot of images and so on to prepare... I will calmly investigate later.
Anyway, thank's for your support.
Paolo
