I use the responsive menu and my sub menu include 16 pages.
But I can only see 13. Is it possible to scoll or to make the height of the icons of the submenu smaller.
Any idea to see all fields?
https://www.dropbox.com/s/hq0m8uu1rhsx8 ... 9.png?dl=0
responsive menu - change size
Re: responsive menu - change size
I'm sorry, there is currently no option for scrolling.T his would require a redesign of the way the menu works,
But you can post suggestions here:
http://quickandeasywebbuilder.com/forum ... m.php?f=28
If other users also find it useful then I may add it in a future update.
Or it is a way to reduce the height of the sub-menu?
The height of the sub menu is determined by the size of the text and the padding. Both can be configured in the properties.
Thanks a lot.
The padding is working fine.
Maybe in future it will be possible to adjust the font size for main and submenu separately.
