website subpages path
Zwerg
Post by Zwerg »
before I buy your nice program I used many years NetObjects Fusion.
So for example the path for a subpage was like this.
http://www.frank-keil.de/Selectrix/Sx-D ... coder.html
With your program it is much shorter
http://www.frank-keil.de/Sx-Decoder.html
Everything is working fine but all links in the internet and search engines like google, etc find the old links. It is possible to generate the old type of structure?
Re: website subpages path
You can create a folder structure in the Site Manager.
http://quickandeasywebbuilder.com/site_manager.html
Zwerg
Post by Zwerg »
you mean like this?
https://www.dropbox.com/s/uu3i7nufl6kno ... 0.png?dl=0
But everything is in the main folder.
What is wrong?
You did not create folders. You have added the pages as sub pages, this will not affect the published structure.
Please see 'Add a new folder to your web site':
