Centering Page on Workscreen?
LTCSZ
Post by LTCSZ »
Hi: I am a very new user of the program...How can I center the work I am doing on the work screen so that it appears as it will on the webpage? All of my entries seem to be off-center...Thanks a lot!
Steve
Re: Centering Page on Workscreen?
For fixed/absolute layouts, you can enable 'center in browser' in the page properties.
If you are using flexible layout then this option should be off and the alignment must be set in the layout grid.
LTCSZ
Post by LTCSZ »
As I said, I'm really new! Where do I find page properties? Thanks for your patience!
Steve
Post by mexman »
Hi Steve:
I suggest you check the HELP function (F1) first. See page 12 as a first step. As well the online tutorials are very helpful.
The page properties are available in the Properties Inspector (bottom-right corner) when no objects are selected.
http://quickandeasywebbuilder.com/introduction.html
